Date/Time: Tue, 26 Nov 2024 04:35:17 +0000
Sierra Chart: Services Balance Too Low message
View Count: 313
[2023-12-30 02:12:43] |
User243538 - Posts: 4 |
Hello Sierra support, I just got a message that services balance is low abd I need to add funds. To avoid this type of an issue, I've enabled auto payment through stripe and my understanding was that package and exchabge/any recurring fee would be auto collected. Is that not the case?. Do I really need to remember ti pay every month manually? Please advise |
[2024-01-02 04:27:40] |
Sierra_Chart Engineering - Posts: 17179 |
At this time you have sufficient funds on your account. So no need to be concerned about adding more.
[2024-01-02 04:54:40] |
Thanks for confirming. I would still like to know whether the recurring charges will be auto paid through autopayment enabled on my account through stripe or I'll have to manually add funds every month?. Thanks |
[2024-01-02 05:23:22] |
There should not be a problem but you can check all of your transactions here: https://www.sierrachart.com/UserControlPanel.php?page=TransactionLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-02 06:00:40] |
Thanks. Looks like auto pay should work.
