Date/Time: Tue, 26 Nov 2024 04:14:19 +0000
New user: need to understand data subscription
View Count: 233
[2023-12-29 20:42:46] |
xnine capital - Posts: 4 |
Hi I am moving to Sierra Charts from NT 8. I will be using Amp as my brokerage and Jigsaw to execute all my orders. I plan to sign up with CQG through AMP unless you all have a way to connect to Jigsaw, too, for execution. Is this possible? I plan to use Sierra Charts for charts. Assuming I can't connect Jigsaw to Sierra Charts for executing trades and I use SC for only data and charting, what service package do I need to get real time level 2 data for futures at cme, globex, cbot, etc. I trade ZN, GC, ES and CL. Thanks |
[2023-12-30 09:13:00] |
Sierra_Chart Engineering - Posts: 17179 |
You will need service package 10 and you will need to pay for the relevant exchange fees for real-time data. For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing We do recommend using Teton order routing instead of CQG: Sierra Chart Teton Futures Order Routing We do recommend using Sierra Chart for trading. You will have a much higher quality order routing as compared to CQG. The documentation link above explains all of that. For more information about Sierra Chart trading, refer to: Overview of Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-30 09:16:31
