Date/Time: Tue, 26 Nov 2024 04:46:58 +0000
[Programming Help] - Chart bar colors changing as I scroll?
View Count: 221
[2023-12-29 17:02:55]
User209431 - Posts: 108
Not sure what is happening. I am using a custom indicator that was all working fine. Now it colors the bars as I scroll differently in large groups of red or green candlesticks?
[2023-12-29 17:26:48]
Welp the indicator vendor feels it may be because my old version was 2568 and now I am on 2576 on the new pc. Not sure what to do.
[2023-12-29 18:02:39]
John - SC Support - Posts: 36286
If this is truly an issue with the study due to a version difference, then the creator of the study would need to update it for the current release.
One other possibility is that the study has to be properly setup if it is being used in a region other than region 1. Our "Color Bar Based on Alert Condition" does this, where if you do not change any of the Inputs and just set it to Region 2 with an Alert Condition of "=1" (so the alert is always true for all bars), if you then move the Main Price Graph into the region the bars will color and will not color when out of the region. We wonder if your study has a similar issue.
[2023-12-29 18:03:45]
Nah, he has it working. Not sure what happened here but I am pretty much dead in the water. All the work I did is gone. I've tried to rebuild from scratch but no luck. No clue if it is something with SC or the indicator but I am pretty much beat down from dealing with this the last 12 hours.
[2023-12-29 18:26:54]
Thanks John but no luck. I
The only thing I can say is there should be a summary which changes gradient colors and have multiple colors for volume stuff but everything is staying 1 color. Every scroll click everything changes to green, 1 scroll click and it all turns red.
That is the behavior that was not occurring on the old PC. I only have this indicator loaded , not sure what is happening or why.
Thanks for any help,
[2023-12-29 19:07:07]
I may have gotten it with a GUI driver issue. Sorry for any hassles, I was dealing with this all night and got little sleep, frustration was very high.
