Date/Time: Tue, 26 Nov 2024 04:44:22 +0000
draw volume profile
View Count: 187
[2023-12-29 15:46:54] |
User693935 - Posts: 10 |
went over "Step by step instructions to configure the draw volume profile tool" several times and still can't change value area colors from the defaults. 1. highlights are in yes position and draw styles in visible position Date Time Of Last Edit: 2023-12-29 15:47:03
[2023-12-29 16:11:36] |
John - SC Support - Posts: 36286 |
We are not seeing any issue with this. We just setup a configuration with a different color for the Value Area and it is working correctly. Do you have the "Bid Volume and Ask Volume Coloring Method" set to something other than "None"? If so, then the Bid/Ask coloring is going to override the Value Area coloring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
