Date/Time: Tue, 26 Nov 2024 04:52:47 +0000
Text Size
View Count: 171
[2023-12-29 14:07:16] |
User246855 - Posts: 1 |
Hello . How can i modify the text size when i automatically cross my POC, VVA... Thanks |
20231229_125800.jpg / V - Attached On 2023-12-29 14:07:13 UTC - Size: 2.88 MB - 68 views |
[2023-12-29 15:52:56] |
John - SC Support - Posts: 36286 |
If you are wanting to change the size of the text based on some condition, then there is not a built-in way to do this. You could create a custom study that does this for drawings, but there is not a way to change the font for the Name and Value labels without changing the global text font. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
