Date/Time: Tue, 26 Nov 2024 04:41:22 +0000
Volume Profile Offset (TPO's current period)
View Count: 239
[2023-12-28 20:19:33] |
User965369 - Posts: 11 |
Hi, I'm having trouble adjusting the position of the volume profile in relation to the right edge of the chart window. Specifically, I'm dealing with a volume profile that only pertains to the current TPO period. I'd like to shift the volume profile (volume by price) slightly to the left, rather than having it fixed to the right edge of the chart window. This change would allow me to clearly view labels, such as "a" and "b" in this scenario (refer to the attachment). Sometimes, when the labels are long and the volume bars are small, I struggle to view the volume. Could anyone provide assistance? Thank you. |
tpo vol sierra.jpg / V - Attached On 2023-12-28 20:01:10 UTC - Size: 8.91 KB - 65 views |
[2023-12-28 20:31:36] |
John - SC Support - Posts: 36286 |
Is that Volume by Price profile associated with the TPO? Or is that an independent profile?
[2023-12-29 14:29:20] |
It's an independent profile. <Volume graph period type> One Period From Most Recent Period Start to End <Set as Independent Volume Profile for TPO Chart> Yes <Time Period Type for 'Fixed Time'> Minutes <Time Period Length for 'Fixed Time'> 30 |
[2023-12-29 16:02:38] |
There is not an option to move the profile off from the DOM. When it is an independent profile, it will be placed where it is. One option would be to have 2 profiles that are both set as Independent, and set the one that is abutted to the DOM to be a period that is small enough that there will not be many bars, then set the second to be what you actually want. Or, another option is to use the "Label Column" for your labels. Refer to the following: Global Trade Settings Windows: Label Column For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
