Date/Time: Tue, 26 Nov 2024 04:25:09 +0000
the color of the candle wick and the color of the candle frame
View Count: 207
[2023-12-28 18:12:21] |
Piotr Grzegorzek - Posts: 21 |
Would it be possible to set the candle frame color and candle wick color separately? As in the attached image.
ticket 2.JPG / V - Attached On 2023-12-28 18:11:58 UTC - Size: 151.24 KB - 59 views |
[2023-12-28 20:07:13] |
John - SC Support - Posts: 36286 |
The Wick color is controlled by the following Graphics Settings: - Bar High-Low Down - Bar High-Low Up The other candlestick colors are defined by the following graphics settings: - Candlestick Up Outline - Candlestick Up Fill - Candlestick Down Outline - Candlestick Down Fill Refer to the following: Graphics Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
