Date/Time: Tue, 26 Nov 2024 04:52:00 +0000
order labels on the right and order lines across the entire chart
View Count: 182
[2023-12-28 18:03:32]
Piotr Grzegorzek - Posts: 21
Would it be possible to set the order labels to the right and the order lines so that they are visible across the entire width of the chart? Just like in the attached image.
imageticket 1.JPG / V - Attached On 2023-12-28 18:02:38 UTC - Size: 158.16 KB - 58 views
[2023-12-28 20:03:10]
John - SC Support - Posts: 36286
We do not have an option for this.
