Date/Time: Tue, 26 Nov 2024 06:51:45 +0000
disable poc value in VbP studie
View Count: 187
[2023-12-28 07:29:42] |
User993113 - Posts: 73 |
Hello, I created this chart with VbP 30 minutes, it bothers me to see the POC in fuchsia with value, how can I disable it? Thank you in advance https://www.sierrachart.com/image.php?Image=1703748167431.png |
[2023-12-28 16:08:30] |
John - SC Support - Posts: 36286 |
It looks like you have the Value Label enabled. Disable this. Refer to the following: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
