Date/Time: Tue, 26 Nov 2024 06:36:08 +0000
Description Fix in General Settings>>Alerts
View Count: 204
[2023-12-27 22:27:47]
Luger9 - Posts: 1
Good Day to You,
Low priority item and which may already be on the to-do list, but have not seen it when I searched.
General Settings>>Alerts>>User Defined Name
"User Defined Name" -> This description should be aligned with the text fill box
"Use User Defined Name Only in Alert Message" -> This description should be aligned with the second Yes/No box.
Note the blue arrow at the bottom of the linked image showing the description swap needed.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=93078
Please delete this thread after noting it for workflow.
imageAlert Description Text.JPG / V - Attached On 2023-12-27 22:07:16 UTC - Size: 124.03 KB - 61 views
[2023-12-27 23:45:27]
Sierra_Chart Engineering - Posts: 17179
We are checking on this. That does not look right.
