Date/Time: Tue, 26 Nov 2024 06:44:01 +0000
Real time data
View Count: 199
[2023-12-27 13:53:27]
User932725 - Posts: 1
I am looking for real time data so I can use sierra for charting only.
How do I get just live CME data?
[2023-12-27 17:15:20]
John - SC Support - Posts: 36286
First, you need to be aware that in order to get real-time data for the CME Group at the non-professional rates, you need to have a live, funded, futures trading account to which you can connect your Sierra Chart software at least once a month. For more information on this requirement, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have an account that will meet these requirements, then we recommend the solution outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have the above worked out, then follow the instructions at the following link to setup the CME Group data:
