Date/Time: Tue, 26 Nov 2024 06:23:52 +0000
How to show the Total Bid/Ask Pulling/Stacking sum
View Count: 365
[2023-12-26 22:31:08] |
singhraj4u - Posts: 5 |
I've incorporated Bid and Ask Market Depth Pulling/Stacking into the Trading DOM, configuring it to display the last 24 levels. However, the sum of values that are not visible by default needs to be shown. Can you assist in setting this up? I've attached the DOM image, emphasizing the section where I anticipate the total pulling and stacking values on both Bid and Ask sides to be displayed.
pullingstacking.PNG / V - Attached On 2023-12-26 22:30:57 UTC - Size: 114.79 KB - 118 views pullingstackingBID.PNG / V - Attached On 2023-12-26 22:31:04 UTC - Size: 121.21 KB - 93 views |
[2023-12-26 22:32:12] |
John - SC Support - Posts: 36286 |
There is not an option within Sierra Chart to do what you are wanting. If you limit the number of Pulling/Stacking levels, then you will only get the sum of the Pulling/Stacking for that number of levels. And if you want to have the sum of the Pulling/Stacking across the entire range of Market Depth, then you can not limit the number of levels that are displayed.
