Date/Time: Tue, 26 Nov 2024 06:35:53 +0000
using a different computer
View Count: 162
[2023-12-26 22:20:10] |
User730394 - Posts: 2 |
logging into a different computer with my Sierra account, but all the charts aren't showing up under file. The only one available is the chartbook example.
[2023-12-27 04:49:34] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
