Date/Time: Tue, 26 Nov 2024 06:41:00 +0000
[Locked] - Chart Window Drawings
View Count: 231
[2023-12-26 22:11:44]
Kadodia12 - Posts: 12
Hi
I used to have my lines from the market profile window extended through to my VWAP chart window. However, when I opened the software this morning I noticed they had disappeared from the second window.
Please could you tell me how to extend the lines from one window to another, as I can't remember how I did it
[2023-12-26 22:13:26]
John - SC Support - Posts: 36286
You can copy drawings from one chart to another. Refer to the following:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
But there is not a way to have lines produced by the TPO study automatically show up in another chart.
[2023-12-28 13:30:04]
Hi
Is there a way to duplicate the chart window I have so I can log in to 2 separate trading accounts?
[2023-12-28 16:22:08]
You would need to install a second Sierra Chart in order to be able to log into two different trading accounts. As long as this installation is on the same computer, then there are no additional fees or issues with doing this. Refer to the instructions here:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
