Date/Time: Tue, 26 Nov 2024 06:43:59 +0000
trade > show positions > p/l error?
View Count: 197
[2023-12-26 20:14:06] |
User725043 - Posts: 35 |
Hi, On 1 lot NQ getting a weird 1 penny at the end of the P/L on the Show Positions line on the chart. Seems odd as the tick size is 0.25. Please see attached image. Had clicked Chart Settings > Global Symbol Settings > Apply Global Symbol Settings prior to trading. Also attached the settings for your convenience. Is there something else needed to be done? |
Private File Private File |
[2023-12-27 14:40:01] |
Hi, The error is showing again today in the Teton NQ connection. There is a $0.01 extra showing on the position P/L line. Please see attached image. Could you kindly advise how to fix? This does not show up in the other Teton contract connections. |
Private File |
[2023-12-27 14:46:56] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Trade Activity Log: Profit/Loss Calculation Rounding Error There is no solution to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-27 14:47:47
