Date/Time: Fri, 10 Jul 2026 10:21:50 +0000
Vertical Line Date/Time Truncated
View Count: 694
[2023-12-26 20:04:42]
User676363 - Posts: 90
Problem Description:
The first two digits of year are truncated when text is positioned using Vertical Align: Top
All text is cut in half (or more) making it unreadable if it is horizontally aligned.
Procedure to Reproduce:
1. Create a Vertical Line
2. Edit the Properties:Labels tab
3. Select Date, Time, or Date & Time
4. Select Vertical Align: Top
5. Edit the Properties:Options Tab
6. Set the Text to Vertical Text (or not)
5. Apply the settings and you will see that the date is cut off both horizontally and vertically depending on the orientation set.
I am using Consolas 6 for Tools >> Tool Settings >> General >> Global Chart Drawing Font
But I have also tried larger fonts and non fixed width fonts and they all cut off to some degree...
Here's a visualization of the problem: https://miro.com/app/board/uXjVN_chhyE=/
If anything is not clear, feel free to leave an anonymous comment.
Just right-click and choose Add Comment. I should receive a notification, even if the message is deleted afterwards.
Thank you
