Date/Time: Tue, 26 Nov 2024 06:50:39 +0000
Build Advanced Custom Studies Not Working
View Count: 222
[2023-12-26 18:41:38] |
jackw - Posts: 57 |
Analysis || Build Custom Studies DLL Build || Remote Build Nothing Happens. |
[2023-12-27 16:40:47] |
John - SC Support - Posts: 36286 |
It is most likely working, but we are guessing that the window is opening small, so you are not seeing any of the text. Grab the corner of the window and expand it so you can see the log area. Then do the build again an you will see the information posted in there.
[2023-12-27 17:41:44] |
Sierra_Chart Engineering - Posts: 17179 |
We are going to have a new release out, today to help resolve a problem like this. With the new release you will be able to go to Window >> Reset Windows to reset the position of that Build window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-27 17:42:03
