Date/Time: Tue, 26 Nov 2024 06:45:10 +0000
Not sure which data to activate for rwaal time equities?
View Count: 208
[2023-12-26 16:00:51] |
User209431 - Posts: 108 |
Sorry for being confused. Which real time data do I activate for the #10 plan to trade US equities? The Denali US Equities Consolidated Tape? It says $10 a month , does that add on or which is included with the plan? TIA |
[2023-12-27 16:37:55] |
John - SC Support - Posts: 36286 |
There is no real-time equities data included with a Sierra Chart package. You need to activate (and pay for) the exchange for which you want this data. In this case, the U.S. Equities Consolidated Tape should work for you. If you have not already done so, go through the Setup Instructions for this exchange at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-27 17:38:21] |
Thanks John, I am going to keep paper trading and setting up my charts on delayed until the start of the month and I will activate real time data and get IB routing set up and should be good. Thanks for the links and help! |
