Date/Time: Tue, 26 Nov 2024 06:28:41 +0000
update autopay
View Count: 189
[2023-12-26 15:13:10] |
RamRally - Posts: 24 |
Hi- I'm not finding an option to update my autopay.
[2023-12-27 16:34:18] |
John - SC Support - Posts: 36286 |
You need to delete the existing setup and then enter a new one. Go to the payments page and scroll down to the bottom and select the option for "Manage Automatic Payments". Go through the options in there to get to the point where you can delete the existing card. Then select the button again and enter your new information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
