Date/Time: Tue, 26 Nov 2024 06:50:25 +0000
Trial Activation not working?
View Count: 192
[2023-12-26 07:40:22]
Eifel Nicks - Posts: 2
Hi, I never received the SMS for the trial activation. How can i activate trial?
[2023-12-26 13:10:10]
Sierra_Chart Engineering - Posts: 17179
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
