Date/Time: Wed, 27 Nov 2024 04:34:17 +0000
New bar created before time elapses
View Count: 1042
[2014-07-28 23:43:32] |
onnb - Posts: 662 |
hi, I have code that prints sc.CurrentSystemDateTime to a log file on bar close using sc.GetBarHasClosedStatus. I am using 5 min bars. I see that sometimes I get a print of a time like 11:59:57 seconds (i.e., before the bar should theoretically close). I am guessing that this is because timestamps are coming in with a time that is future relative to my computer clock and so SC creates a new bar thus closing the current bar?
[2014-07-28 23:46:02] |
Yes. This is a logical conclusion. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
