Date/Time: Tue, 26 Nov 2024 06:31:25 +0000
CountDown Timer Chart Study * 2
View Count: 241
[2023-12-25 22:26:00] |
User14953 - Posts: 236 |
Is there a way to have a countdown timer in each of a chart's 2 regions?
[2023-12-27 16:20:24] |
John - SC Support - Posts: 36286 |
It is not supported to have the Countdown Timer anywhere but in the main chart region (Region 1).
[2023-12-27 22:21:49] |
User438057 - Posts: 49 |
??...Count Down Timer in region 2 works fine for me, maybe you have to play with the initial horizontal or vertical position to bring it in view
Date Time Of Last Edit: 2023-12-27 22:25:13
[2023-12-28 15:18:39] |
The first time we tried it, we just did the Countdown Timer by itself in Region 2, which did not work. We added another study and it can be shown in Region 2, but then it is not possible to get another Countdown Timer in Region 1.
