Date/Time: Tue, 26 Nov 2024 06:46:52 +0000
Study: Daily Pivots (Poivot Points - variable period) doesn't plot pivots on Monday
View Count: 225
[2023-12-24 17:49:37] |
BenjFlame - Posts: 324 |
I add this study to a daily chart as you can see in image. However, it never plots pivots on monday. It's correct for any other day. It seems to think that because there was a weekend, then prior data is missing. Changing "Auto skip period of no trading" to "yes", and changing "Minimum required time period as %" to any % value doesn't fix this. |
Screenshot 2023-12-24 124056.png / V - Attached On 2023-12-24 17:49:14 UTC - Size: 62.97 KB - 58 views |
[2023-12-25 00:43:45] |
Sierra_Chart Engineering - Posts: 17179 |
You need to set this Input to Yes: Pivot Points: Auto Skip Period of No Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-25 09:33:18] |
I tested this setting, as you can see in the image, result is even worse: more days are missing, and pivots are completely offset.
Screenshot 2023-12-25 043105.png / V - Attached On 2023-12-25 09:31:52 UTC - Size: 127.86 KB - 55 views |
[2023-12-25 18:09:47] |
This study is very advanced in the way that it works and really you need to use an Intraday chart for the study to be able to determine the true time period of a chart bar. Instructions: Chart Session Times: Creating Daily Bars with Custom Session Times We will see if we can improve the functionality on Historical Daily charts which you are currently using but this is not well supported right now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
