Date/Time: Tue, 26 Nov 2024 06:40:24 +0000
"Color Bar Based on Alert Condition"- Feature Request
View Count: 369
[2023-12-24 12:15:47] |
Sudhirc - Posts: 52 |
Is it possible to have the "Study Subgraph Value When True (In:15) " on the price panel instead on secondary panel once the condition is me. For example on the attached graph, when a condition is met i can print the required value on the secondary panel (in this case %K value when the condition is met). by having the following setting under Setting and Inputs panel Output when condition True (In:4)- Study Subgraph Reference Study Subgraph Reference Value When True (In:15) - ID1.SG1 (in this case %K value) and under Subgraphs panel by selecting - Draw Style : Value of Subgraph But can you add an option to the study where i can option to have the value get printed on price panel with the option to print at high/low/or close of bar with offset. like Input name --- Subgraph output: Input Value -- ID0.SG1 (open/high/low/last etc) to choose from. https://www.sierrachart.com/image.php?Image=170341988436.png |
Attachment Deleted. Chartbook18.Cht - Attached On 2023-12-24 12:15:35 UTC - Size: 4.85 KB - 98 views |
[2023-12-24 23:43:53] |
Ticks - Posts: 183 |
What you are requesting. It can already be done. |
[2023-12-25 00:02:08] |
Sierra_Chart Engineering - Posts: 17179 |
Yes, it is already supported. We are in the process of updating the documentation.
[2023-12-28 00:27:31] |
Yes arrows and texts can be done, that's not what I'm requesting. If you look at the attached pic, i had an alert condition based on "Color Bar Based on Alert Condition" and was when the condition is met, i was able to print the desired %K value (#) on Stochastic's. (which is in Panel 2) (this was done by Color Bar Based on Alert Condition - Output when Condition is True In:4 - selecting to: Study Subgraph Reference and Study Subgraph Reference Value In: 15 - IS1.SG1 - This is now printed on panel 2 on Stochastics How can i get this value printed on the main price chart? (manually - annotated on price panel in white in the attached picture) https://www.sierrachart.com/image.php?Image=170341988436.png Date Time Of Last Edit: 2023-12-28 00:29:32
[2023-12-28 01:09:39] |
Do you mean like this screenshot attached? If so, use a spreadsheet formula study and set draw zero values to No. Date Time Of Last Edit: 2023-12-28 01:19:00
Capture.PNG / V - Attached On 2023-12-28 01:08:35 UTC - Size: 8.52 KB - 74 views |
[2023-12-28 01:28:30] |
Ticks, Yes that is what I'm looking for Never worked with spreadsheet Formula, i will work on it. Do you mind putting it together if it is not too much trouble. I have everything in chartbook18.cht attached to my first post. Thank you so much edit: Sorry, Spreadsheet Formula Study- DOES NOT WORK. Reason: I'm not calculating based on a formula in Spreadsheet Formula - When the condition is met as in ID3 or ID4 (in the attached chartbook, THEN get value from ID1.SG1 and print in panel 1) - this cannot be done with Spreadsheet Formula to the best of my knowledge. Thank you for looking into it. Date Time Of Last Edit: 2023-12-28 01:52:51
[2023-12-28 02:03:42] |
Just because it says spreadsheet formula. It does not mean you can only use a spreadsheet formula structure. It says this in the spreadsheet formula documentation. You can use the same if, and, or statements that are used in a color Bar Based on Alert Condition formula. IF(whatever value you need to be,ID1.SG1,0) As an example: In the screenshot, I showed you. This is the formula I used to get those number values. if( and( ID0.SG23[-2]> ID0.SG22[-2],ID2.SG7 > 0, (H[-1] - L ) / ticksize >=TICKSIZE*ID19.SG10 ),(H[-1] -L ) / ticksize, 0)
Date Time Of Last Edit: 2023-12-28 02:19:54
[2023-12-28 03:49:34] |
Ticks, awesome, thank you so much sir.
