Date/Time: Tue, 26 Nov 2024 06:45:51 +0000
Data not loading on DOM chart for 10 yr treasuries ZNH24-CBOT
View Count: 183
[2023-12-22 19:51:53] |
Robbo - Posts: 6 |
Dear support as per subject, I have tried following instructions from G7FX training and the data is not rolling over and appearing on my dom chart for ZNH24-CBOT? please login to my charts to see, thank you for your assistance, regards Robert Collins.That problem has been fixed but the data has stopped coming again, does it run 24/7? sorry for my ignorance but I am only starting out, thank you again and best wishes.
Date Time Of Last Edit: 2023-12-23 08:11:51
[2023-12-27 15:53:26] |
John - SC Support - Posts: 36286 |
The contract specifications for ZN can be found here: https://www.cmegroup.com/markets/interest-rates/us-treasury/10-year-us-treasury-note.contractSpecs.html Keep in mind that you are using our Delayed Streaming data, so your data will be 10 minutes and 10 seconds behind the real-time data. This should not have any impact on whether you are getting the data or not, however. If you are still having an issue, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
