Date/Time: Tue, 26 Nov 2024 06:54:40 +0000
[Programming Help] - GET VOLUME BY PRICE STUDY VALUES (POC, VAH, VAL)
View Count: 298
[2023-12-22 16:04:59] |
User103688 - Posts: 9 |
Hi everyone, I'm trying to get the value of POC, VAH, VAL from VbP study to my custom study. SCFloatArray otherStudyData;
sc.GetStudyArray(1, 1, otherStudyData); The subgraph of POC is the first one. but if I try to print it on Message Log, result like 0. float subgraphValue = otherStudyData[sc.Index]; // Prepare the log message SCString logMessage; logMessage.Format("Subgraph value at current bar: %f", subgraphValue); // Add the message to the log sc.AddMessageToLog(logMessage, 0); Can you help me, please? |
[2023-12-23 20:29:24] |
LudaTrades - Posts: 27 |
Try using sc.GetStudyProfileInformation(), this function is more suited to that purpose I think. sc.GetStudyProfileInformation Using sc.GetStudyArray you can run into calculation precedence causing 0 values to return. You probably also have to be sure your VbP draw mode set correctly, just off the top of my head. I would just use sc.GetStudyProfileInformation(), otherwise refer to sc.GetStudyArray() and ACSIL Interface Members - Variables and Arrays: sc.CalculationPrecedence |
