Date/Time: Tue, 26 Nov 2024 06:33:05 +0000
Version 2568 J94 cell not updating on replay
View Count: 232
[2023-12-21 15:49:34] |
User104854 - Posts: 456 |
I recently upgraded to this version and on replay the cell, J94 is not updating as the order is moved. I've included a couple of screenshots. In both cases the order is at a different price and J94 isn't at either price. It is not updating. This has always worked fine on previous versions. As I've moved the order, cell J94 updates the price to wherever the order is at. I use this cell for a few things including to cancel orders. Can you take a look and fix it please? It's not remotely close to working and it's always worked before. Thank you. Date Time Of Last Edit: 2023-12-21 19:51:35
Private File Private File |
[2023-12-23 00:54:28] |
Is this something you can fix? I'm not making this up. It is a legitimate issue that has worked on previous versions and is not working on this version.
[2023-12-23 01:26:15] |
Sierra_Chart Engineering - Posts: 17179 |
We are not able to reproduce this. And we do remember you reported this before and we did test this before. Check this Input to make sure it is set as you expect: Spreadsheet Study Inputs: Use Column I and J Values Version 2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-23 14:50:58] |
Thank you for the reply. I currently have that setting set to 'no'. When I changed it to 'yes' it didn't fix it. I just switched to version 2567 and it is working just fine. I don't understand it. |
