Date/Time: Tue, 26 Nov 2024 06:34:21 +0000
Status bar position, alert, disconnect
View Count: 172
[2023-12-21 10:26:38]
tokauo - Posts: 32
I would like to ask you few question about Status bar:
1) I had some problems with internet connection recently... but Status bar didn't change its color. Is it function that SB should do or is SB only controlling data?
2) Is it possible to have sound Alert for internet disconnection?
3) If I understand to this Detaching and Attaching Chart Windows: Detaching a Chart photo right, SB is aligned to the right, on the symbol line? If yes, how can I to attach it there?
Thanks you
Tom
[2023-12-21 16:15:27]
John - SC Support - Posts: 36286
1. You may not visibly see a lost connection in the Status Bar. Since the connections are handled through what we call sub services.
2. Yes refer to:
General Settings Window: Server Connection Lost Alert (Global Settings >> General Settings >> Alerts >> Other Alerts)
3. You just need to move it through the "Global Settings >> Customize Control Bar" and move the Status Bar down in the list, which moves it to the right for a horizontally displayed control bar.
