Date/Time: Tue, 26 Nov 2024 06:37:20 +0000
Volume by price study on DOM - can you change the text colouring by dominant bid or ask
View Count: 178
[2023-12-21 07:31:50] |
User297187 - Posts: 12 |
Hi, I currently have a couple of VbP studies on my DOM that display bid x ask with no bars/colouring. Is there anyway to have the text of the dominant side at each price highlighted eg red and green? Thanks |
[2023-12-21 14:09:52] |
John - SC Support - Posts: 36286 |
There is not a way to color the text based on the dominant side. You can color the Volume Bars based on dominance, refer to the following: Volume By Price Study: Bid Volume and Ask Volume Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
