Date/Time: Tue, 26 Nov 2024 06:33:05 +0000
Alert sound not sounding each time there is a fill
View Count: 212
[2023-12-20 20:38:31] |
User986474 - Posts: 26 |
How do I get the alert sound to sound every time there is a fill?
[2023-12-21 13:50:23] |
John - SC Support - Posts: 36286 |
If you are not getting any alerts, then refer to the following: Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications) If the above is set, but you are still not getting the sound, then refer to the following: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play If you are getting an alert, but only one, then refer to the following setting: Global Trade Settings Windows: Skip Trade Order Alert if Within N Seconds of Previous Trade Order Alert Type (Global Settings >> General Trade Settings >> Notifications) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-21 14:23:53] |
I want alert to sound EVERY time an order is filled with no number of seconds in between involved. How is this set?
[2023-12-21 16:24:22] |
Enter 0 for that setting.
[2023-12-21 17:49:55] |
Where is that setting and where do I enter 0?
[2023-12-21 19:39:42] |
Sierra_Chart Engineering - Posts: 17179 |
You need to update to the latest prerelease for this: Software Download: Fast Update Make sure you update to the "prerelease". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
