Date/Time: Tue, 26 Nov 2024 06:40:55 +0000
DPL Discrepancy
View Count: 186
[2023-12-20 09:08:20] |
Kadodia12 - Posts: 12 |
Hi Yesterday (19/12) on my Rithmic account, I generated a total profit of ~$500 and yet, my DPL displayed around -400 at the end of the day from the last trade. This was also registered on my rithmic account balance, even though my trades were profitable. Could you please investigate this issue as a matter of urgency. Thanks Umair |
[2023-12-20 14:18:25] |
John - SC Support - Posts: 36286 |
If Sierra Chart and Rithmic are showing the same values, then this would imply that it is the correct DPL, as these are calculated separate from each other. We do not have a way to view the information. All of this is located on your system. Refer to the following for how to analyze the Daily Profit/Loss to find an issue (although it does not sound like there is one): Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
