Date/Time: Tue, 26 Nov 2024 06:46:08 +0000
Unable to modify tool text via right-click context menu (version 2571)
View Count: 224
[2023-12-19 14:40:23]
emmanuel - Posts: 58
On version 2571 I'm unable to set/modify the text of a tool added to a chart, using the context menu.
1. Open a chart.
2. Select a tool, such as a vertical line, and add it to the chart.
3. Right-click on the tool and select "Modify text."
Normally, when "modify text" is selected from the context menu, it opens a dialog box which allows editing the text. However, the dialog is not showing.
I'm able to edit the text by using "Toosl/Manage chart drawings window."
[2023-12-19 15:51:16]
John - SC Support - Posts: 36286
We are able to reproduce this and will look into it.
[2023-12-19 20:26:35]
Sierra_Chart Engineering - Posts: 17179
We are checking on this.
[2023-12-20 00:51:52]
This will be resolved in the next release. We will put this out before morning.
