Date/Time: Tue, 26 Nov 2024 07:01:04 +0000
How to get the same chartbook set up from an old laptop to a new one
View Count: 267
[2023-12-17 22:00:23]
User146885 - Posts: 1
Hello support.
I installed sierra Chart in a new laptop( the one im going to be using from now on) i would like to know how can i do to get the same chartbooks setup that i have now in my old laptop? i made a custom footprint chart and a custom DOM as well. It was really not an easy task so iam a little concern about losing all of the custom items once a disinstall it from my old one.
Now at the present moment i have 2 laptops running sierra chart software, and i dont seem to find the way to solve this issue.
Should I disinstall the software from my old laptop and once i do this my new laptop running sierra chart will automatically have the same set ups i have now in my old one?
I am not interested in paying extra denali exchange data feed.
Thank you so much for your help.
[2023-12-18 01:47:17]
Sierra_Chart Engineering - Posts: 17179
You just copy the Chartbook files from the Data Files Folder of your original installation, to the Data Files Folder to the new installation. More information is here:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
You could put the files, on a USB drive.
