Date/Time: Tue, 26 Nov 2024 06:27:17 +0000
Market Replay for Two charts?
View Count: 277
[2023-12-17 21:43:15] |
krypto101 - Posts: 33 |
Hi I'm trying to use market replay for two charts, left chart being RTH TPO and Right chart showing Renko. For some reason they both seem to be using moving on different time frames and I'm not sure why I'm on ES using Pacific time so the market should open at 6:30AM Date Time Of Last Edit: 2023-12-17 21:44:17
repaly.png / V - Attached On 2023-12-17 21:42:39 UTC - Size: 800.58 KB - 70 views |
[2023-12-18 14:51:33] |
John - SC Support - Posts: 36286 |
Please give us a chartbook with those charts in it so we can take a look. They should be in sync from what we see of your settings. Refer to the following for how to get us the Chartbook, just get us the 2 charts, not just 1 as called out in the instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-21 08:24:08] |
Here's the chart book
Main_Replay FIX.Cht - Attached On 2023-12-21 08:23:31 UTC - Size: 41.03 KB - 376 views |
[2023-12-21 16:05:34] |
You do not have the same number of days loaded in the two charts, so you do not have data that goes to where you are starting the replay from in the VWAP chart. You have to have the data loaded going back to where the replay will start from or it is not possible for all the charts to be synchronized. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
