Date/Time: Tue, 26 Nov 2024 06:46:49 +0000
Version 2568
View Count: 309
[2023-12-17 19:07:27] |
User846910 - Posts: 8 |
Hi, Will I have to update to the new version if I am only using Intraday charts but have the "Continuous Futures Contract - Volume Based" setting selected? If I recall correctly, the Continuous option checks the *.dly files for when to roll. |
[2023-12-17 20:12:51] |
Sierra_Chart Engineering - Posts: 17179 |
There is a reliance on Historical Daily data in this case and you will need to update but we are not planning to require the update until next year. Sometime in January.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-17 20:13:02
[2023-12-20 17:37:10] |
Just to clarify, this means I can ignore this message until sometime next year? - 2023-12-14: To continue to receive historical Daily data in historical charts for stocks and futures, effective December 23, 2023, it is necessary that you update to version 2561 or higher. For instructions, refer to Fast Update. |
[2023-12-20 21:19:37] |
You can ignore it until January 15, 2024.
