Date/Time: Sun, 27 Sep 2026 05:22:42 +0000
help needed for number bars
View Count: 1409
[2014-07-28 16:33:12]
User22099 - Posts: 8
I am using interactive brokers connection and needed help with configuring number bars study for same
[2014-07-28 16:58:21]
Refer to the documentation here:
Numbers Bars: Step-By-Step Instructions
After you follow through the instructions, if you have a problem, post an image of the chart, by following these instructions:
Keep in mind that the historical data from Interactive Brokers is not tick by tick data and will not work accurately with Numbers Bars.
[2014-07-30 07:35:36]
thanks i understood and worked it out , i wanted to know 2 things
1. difference between tick and trade
2. in your chart settings what does tick size mean
thanks
[2014-07-30 09:31:52]
Go to this page and reload it:
Numbers Bars: Definitions
We have updated the Definitions section to answer these questions.
