Date/Time: Tue, 26 Nov 2024 07:01:38 +0000
Common Trade Activity Log across multiple instances?
View Count: 253
[2023-12-16 21:24:17] |
User254520 - Posts: 16 |
Hello, I am running Accurate Trading System Back test Mode in SIM across multiple instances of SC, across multiple products and would like to understand if there is a way to aggregate Trade Activity Log Statistics into one to get accurate common drawdown. If it's not possible, is there another solution that exists for what I've described above? Thank you |
[2023-12-18 14:43:47] |
John - SC Support - Posts: 36286 |
You can export and import fills. Refer to the following: Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
