Date/Time: Tue, 26 Nov 2024 06:43:28 +0000
[Programming Help] - Is it possible to set value in sc.SetDefaults from input ?
View Count: 277
[2023-12-16 13:37:26]
BenjFlame - Posts: 324
is it possible to conditionally set value in sc.SetDefaults, from and SCInputRef ?
So for example if I want to set sc.GraphRegion value conditionally from SCInputRef, is it possible ?
[2023-12-16 18:08:55]
User719512 - Posts: 264
Yes, see also ACSIL Interface Members - Variables and Arrays: sc.GraphRegion
[2023-12-16 23:25:55]
Sierra_Chart Engineering - Posts: 17179
We do not believe this is going to work right. In any case, it would not be considered a reliable method.
Since the Inputs at that point in time are being configured to their default.
So what you need to do is move the setting of sc.GraphRegion below the set defaults code block. And only set it on a full recalculation:
sc.IsFullRecalculation
Date Time Of Last Edit: 2023-12-16 23:26:39
