Date/Time: Tue, 26 Nov 2024 09:51:44 +0000
New version Issues
View Count: 199
[2023-12-15 16:17:01] |
User754680 - Posts: 2 |
Hi Upgraded to the new version and have issues with my data feed and price keeps showing "skipped historical data" also candle stick price doesn't match that on the charts. need help. K |
Capture1.PNG / V - Attached On 2023-12-15 16:12:31 UTC - Size: 3.83 KB - 50 views Capture2.PNG / V - Attached On 2023-12-15 16:14:03 UTC - Size: 11.18 KB - 53 views |
[2023-12-15 16:26:27] |
Sierra_Chart Engineering - Posts: 17179 |
We see you are using Rithmic. There are issues when using Rithmic. You really need to use our Denali data feed. Refer to: Rithmic Trading Platform Service: Rithmic Market Data and Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
