Date/Time: Tue, 26 Nov 2024 06:59:35 +0000
How to access visible bars using the Alerts script? (Color Bar Based on Alert Condition)
View Count: 200
[2023-12-15 16:14:37] |
funbun - Posts: 90 |
I saw it's possible in the forum somewhere but I cant find it...
[2023-12-15 17:27:40] |
John - SC Support - Posts: 36286 |
We need more information on exactly what you are wanting to do. We do not understand what you are looking for in terms of 'Accessing Visible Bars'.
[2023-12-15 19:13:06] |
For example - Within the Alerts tab, be able to compute the cumulative volume of the visible bars only and apply some mathematical calculation on that. I know there's MAX[-1:-20] to manipulate values of previous bars but the question is if I the Alerts knows how to access the data on the visible bars only, without hard coding the bars range. |
[2023-12-15 19:24:35] |
There is no functionality within Alerts or Spreadsheets to know the visible bars of the chart. To do this, you would need to create a custom study. refer to the following for this: ACSIL Interface Members - Variables and Arrays: sc.IndexOfFirstVisibleBar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
