Date/Time: Tue, 26 Nov 2024 06:27:48 +0000
Which Package is Best
View Count: 343
[2023-12-15 15:32:26] |
User367832 - Posts: 2 |
Hello SC Community, I'm trying to decide which SC package and data feed is best. I want CME Bundle with Market Depth, but which package would suit me best considering I use pulling and stacking information and recent volume. I dont need MBO data. Thanks |
[2023-12-15 17:21:28] |
John - SC Support - Posts: 36286 |
the main difference between the "Standard" and the "Advanced" packages is about access to the "Numbers Bars" and "TPO" studies (along with a couple more). And there is our highest package - "Integrated Advanced with MBO" that adds the MBO data, which you state you do not need. So we are not sure whether you need the "Standard" or "Advanced" based on what you state. But you do need to be on one of the "Integrated" packages in order to be able to connect to a trading service and/or to get real-time data. Refer to the differences in the Integrated packages at the following link: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-15 19:36:24] |
Whichever package that allows me to receive pulling and stacking data
[2023-12-15 19:44:08] |
All packages give you access to the Pulling/Stacking. You just need to ensure that you activate an exchange that includes the Market Depth data.
