Date/Time: Tue, 26 Nov 2024 09:40:44 +0000
Custom Study above Market Depth History
View Count: 227
[2023-12-15 12:03:13] |
chasepatrol - Posts: 7 |
Dear all, I'm trying to put a custom study with boxes and zones in my chart with an Market Depth History Graph. Unfortunately, as you can see in the image, the Market Depth colors are always above my custom study. Is there a way to bring my custom study to the front before the market depth? |
Screenshot 2023-12-15 130012.png / V - Attached On 2023-12-15 12:02:58 UTC - Size: 111.64 KB - 61 views |
[2023-12-15 14:51:07] |
John - SC Support - Posts: 36286 |
Refer to the following: Chart Studies: Study Display Order For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-15 15:04:43] |
Hi John, yes I thought the same and I guess I understood the Study Display Order rules but it does not work. Please see in the first screenshot it's about the grey "Stalkzones". They are behind the market depth graph even with the right order and with restarting the software. I guess I get something wrong. Or is it because it is a "custom study"? |
[2023-12-15 16:51:16] |
The Market Depth Historical Graph is handled special and should always be in the background regardless of the order. Is your custom study putting Drawings on the screen? or is it plotting a Subgraph? Also, please give us an image of the chart with just your study on it, and then an image with your study and the Market Depth Historical Graph. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
