Date/Time: Tue, 26 Nov 2024 09:46:01 +0000
[Programming Help] - repeating numbers on mt range bars
View Count: 298
[2023-12-15 08:14:33]
User791271 - Posts: 4
ive gone through all the support forums and tried to find out why i have repeating numbers for volume and delta on my number bars would love to get feedback on how to make it so i dont have these on my chart
attachmentnew chrt.Cht - Attached On 2023-12-15 08:13:41 UTC - Size: 5.15 KB - 393 views
[2023-12-15 14:47:27]
John - SC Support - Posts: 36286
We need an image of what you are seeing. We can not do anything with your Chartbook until we see the specific issue you are referring to. Follow these instructions to get us an image:
[2023-12-15 15:21:43]
https://www.sierrachart.com/image.php?Image=1702653598913.png
i have my range bars set to 20 ticks and to open new bar on range met yet they still go past 20 ticks and they have repeating numbers as seen on the image
[2023-12-15 17:18:07]
We are not seeing any issues with the chart you sent us. The bars are all a range of 5, except when a new session starts, in which case the previous bar may be cut short, since you have "New Bar at Session Start" set to "Yes".
Also, the Bar Period is set to "Range per Bar - True". You mention that you had it set to "Range per Bar - New Bar at Range Met".
[2023-12-15 17:25:33]
I figured it out I think I was looking at past dates that had some discrepancies but now that I'm watching the market live I'm not seeing what I saw yesterday! Thanks for your time!
[2023-12-15 17:25:34]
