Date/Time: Tue, 26 Nov 2024 09:31:01 +0000
Need
View Count: 244
[2023-12-14 21:06:12] |
User209431 - Posts: 108 |
Trying to figure out how to add "Order Cancelled" and "Order Filled" alerts to my trades executions. I see how to load them but I do not know how to find them. One group where you set them (and can listen to them) is numbered while the ones in my pc folder are file names by description. TIA ***Edit - not sure but post and tile are missing info. Here is the edit for the future. Date Time Of Last Edit: 2023-12-14 22:31:01
[2023-12-14 21:58:59] |
John - SC Support - Posts: 36286 |
What is this about? It looks like this was supposed to be part of another thread.
[2023-12-14 22:02:29] |
Not sure what happend here. It was it's own thread though. Just seems to have no title and half of what I was asking is missing for some reason. What I was looking for was which # sound alerts are "Order filled" and Order Cancelled"? I can't find a way to figure it out. TIA |
[2023-12-14 22:07:08] |
Refer to the following to get the Alert Number for each of these items: Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications) And also refer to the following for how the Alert Sounds are defined: General Settings Window: Alerts (Global Settings >> General Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-14 22:26:44] |
Thanks John, The problem I am having is that in the Global Settings it describes what the sound is and you can listen to it but when I go to Trade > General Setting to add an alert for different events it shows alert number 1-200. I am not sure how to find what numbers are what sounds? |
[2023-12-15 14:22:57] |
In the "General Settings >> Alerts", you set the various options for each of the alert numbers that you want to modify. At the top of that page is the setting for "Alert", which is where you select the specific Alert Number that you are modifying. Refer to the following: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#Alert For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-15 14:42:55] |
Thanks John, all good now.
