Date/Time: Tue, 26 Nov 2024 09:38:53 +0000
Vertical line on a chart at certain hour
View Count: 392
[2023-12-14 20:10:51] |
OriolCasas - Posts: 163 |
Hello, I would like to create a vertical line in a chart at a certain time (Initial Balance) is created. Usually after the first RTH hour. How can I create that? Thank you |
[2023-12-14 20:34:22] |
John - SC Support - Posts: 36286 |
There is the "Date-Time Line" study, but this will only give you one line. If this is something that you want to have for each day at a particular time, then use the Spreadsheet Study and use a formula like the following in cell K3: =IF(AND(HOUR(A3) = 9, MINUTE(A3)=30), 1, 0) Set the "Draw Style" for the K column to "Background" and you can control how thick the line is using the "Width/Size" of the Subgraphs. Refer to the following: Using the Spreadsheet Study Chart Studies: Background (ACSIL: DRAWSTYLE_BACKGROUND) Chart Studies: Subgraphs Tab >> Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-14 22:33:52] |
User719512 - Posts: 264 |
The Sierra study Time Line or Time Range Highlight - Transparent should do this. For the second one, specify a start/end 1 second apart.
