Date/Time: Tue, 26 Nov 2024 09:24:48 +0000
Market Depth Historical Graph Issue
View Count: 224
[2023-12-14 18:02:54] |
WaMBly - Posts: 4 |
For whatever reason, the market depth historical graph will display # of orders at all prices upon opening sierra, but once it's up for longer than around 5mins, it switches to only showing a range of the prior price action that's shown on screen. I never changed anything in study settings and it gets annoying having to close and reopen sierra so often. Any idea how to fix this?
Attachment Deleted. Screenshot 2023-12-14 115033.png / V - Attached On 2023-12-14 17:52:52 UTC - Size: 25.16 KB - 63 views |
[2023-12-14 18:56:20] |
John - SC Support - Posts: 36286 |
The exchange that you have active (Full CME Group for Non-Professional Trading Accounts) does not include Market Depth data. Therefore, what you are seeing is historical market depth data, which is why you do not see the updates on the current bars. Refer to the following for how to change your exchange options to include Market Depth: Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
