Date/Time: Tue, 26 Nov 2024 09:49:37 +0000
NQ Data
View Count: 390
[2023-12-14 15:12:57]
User281826 - Posts: 4
I just switched from CQG to Teton through AMP futures. I've been using Denali for a while. After making the switch, I'm only getting 1 day of NQ data while ES, CL and GC are all fine. I didn't change any chart settings. I can get more NQ data only by turning off the continuous contract option, but I need that.
Any ideas what the problem may be?
Regards,
T
Date Time Of Last Edit: 2023-12-14 15:13:05
[2023-12-14 16:09:16]
John - SC Support - Posts: 36286
There is no reason why you would be limited, unless there has been a change to the Chart Settings.
Refer to the following for how to get more data in your chart:
Loading More Or Less Data into an Intraday Chart
[2023-12-14 17:14:16]
Sierra_Chart Engineering - Posts: 17179
Re-download the data for the last two contract months following these instructions:
Disable the use of Custom symbol settings.
