Date/Time: Tue, 26 Nov 2024 09:30:28 +0000
Volume on Volume Profile Chart Not Matching with Footprint Chart on ES
View Count: 311
[2023-12-14 13:13:21]
User465646 - Posts: 9
The cumulative volume for my volume profile chart is not matching with what is shown on my footprint chart calculated values. I have tried deleting the data and redownloading it but that did not resolve the issue. Please advise how this can be fixed.Attached are screenshots of the calc values on the footprint chart and the volume shown on the volume profile.
Thank you,
imageFootprint calc values 12.13.23 volume.png / V - Attached On 2023-12-14 13:13:05 UTC - Size: 6.53 KB - 54 views
[2023-12-14 13:14:15]
Adding volume profile volume picture
imageVolume profile 12.13.23 volume.png / V - Attached On 2023-12-14 13:13:54 UTC - Size: 4.84 KB - 53 views
[2023-12-14 15:36:18]
John - SC Support - Posts: 36286
Please give us an image of the entire chart by following these instructions:
There is not enough information from the snippets you gave us for us to look into this - in particular, we do not know what symbol this is for, what date you were looking at, etc.
Also, make sure your Volume by Price profile is set for 1 day and includes the Evening Session.
[2023-12-15 14:11:41]
Hi John,
Attached is the chartbook for the volume profile that shows the volume total above the volume profile. The symbol I am looking at is ESH24. I will reply with the other chartbook that has the calculated values reflecting the differing volume total.
attachmentIve_Come_to_Class.Cht - Attached On 2023-12-15 14:09:58 UTC - Size: 18.83 KB - 137 views
[2023-12-15 14:12:20]
Footprint chart with calc values at the bottom
attachmentClasstime.Cht - Attached On 2023-12-15 14:11:54 UTC - Size: 32.23 KB - 172 views
[2023-12-15 16:36:30]
We need to know the specific charts you are comparing (please give us the Chart Numbers).
[2023-12-15 16:46:21]
where do i locate the chart numbers?
[2023-12-15 17:46:13]
With a particular chart selected, select "Chart >> Chart Settings" and in the title bar for that window it will state "Chart Settings | SymbolName BarPeriod ChartNumber | ..."
Pull the Chart Number from the above.
