Date/Time: Tue, 26 Nov 2024 08:31:57 +0000
Trying to upload a custom indicator .dll file
View Count: 201
[2023-12-13 17:33:15] |
User209431 - Posts: 108 |
Welp guess the learning curve frustration is setting in. In your documentation you say: "The location of the Data Files Folder can be found by selecting Global Settings >> General Settings on the menu. The folder is displayed in the Data Files Folder box. " Done this about 20 times and nothing you say here occurs. I see nothing like the picture or am lead to the "data files folder" When I click on "General setting" is open a dialog box and looks nothing like what is explained or shown and there is no "data files folder" to be found. |
[2023-12-13 17:54:01] |
John - SC Support - Posts: 36286 |
It looks like we need to update that part of the documentation for the new Settings windows. That particular item is found by selecting "Global Settings >> General Settings >> Paths" and you will see the "Data Files Folder" listed at the top. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
