Date/Time: Tue, 26 Nov 2024 08:55:15 +0000
Display DOM Depth totals
View Count: 197
[2023-12-13 15:51:46]
countryboy92 - Posts: 91
/This is working properly, but one side is formatted as "48.1K' and the other side "48100". How can I get both sides to display in thousands like the "48.1K"
[2023-12-13 17:22:31]
John - SC Support - Posts: 36286
In the "Trade >> Customize Chart/Trade DOM Columns" there is an option for "Use Size Suffix" for each column. One of your columns has this enabled and the other does not. Set both columns to have this enabled to view the data as ##.#K.
Refer to the following on this:
Global Trade Settings Windows: Use Size Suffix
